EIM/WIM multiple classifications problem - alarm node
msivak
I need some piece of advice with alarm workflow. I would like to select multiple classifications with one alarm node, but boolean "OR" statement is not working properly.
For example: I have category A and category B. I would like to specify Filter-Activity condition based on Relationships. I select :
<object type>-<attribute>-<operator>-<value>-<boolean>
Classification-Classification name-=-A-"OR"
Classification-Classification name-=-B-"AND"
But after "OK" button is pressed and I reopen the alarm node, but the "OR" statement is changed to "AND", so I am unable to filter based on multiple classifications.
Classifications does not contain the same string, so I cannot use for example another operator to reach the selection.
Any advice how to do this? (copying of alarm workflows is such a strange idea:)
