EIM/WIM multiple classifications problem - alarm node
msivak
I need some piece of advice with alarm workflow. I would like to select multiple classifications with one alarm node, but boolean "OR" statement is not working properly.
For example: I have category A and category B. I would like to specify Filter-Activity condition based on Relationships. I select :
<object type>-<attribute>-<operator>-<value>-<boolean>
Classification-Classification name-=-A-"OR"
Classification-Classification name-=-B-"AND"
But after "OK" button is pressed and I reopen the alarm node, but the "OR" statement is changed to "AND", so I am unable to filter based on multiple classifications.
Classifications does not contain the same string, so I cannot use for example another operator to reach the selection.
Any advice how to do this? (copying of alarm workflows is such a strange idea:)
egain_karthik
seems to be a defect, you should be able to evalute condition 1 and condition 2 = result 1
result 1 or condition 3, result 1 and condition 3 etc...
in your case if you have,
classification classification name contains test OR
classification classification name contains test2 OR ----- Result 1
classification classification name contains test3 OR------ Result 2
classification classification name contains test4 AND-----Result 3
and this is not saving then it is a bug and should be filed as such.
Hello Karthik,
thank you for your reply. This issue is probably the bug, because I am able to specify those conditions, but after "Ok" is pressed and "Alarm node" is reopened (before or after "save" is pressed), all the "OR" statements are changed to "AND" statements...
I will open a case for this issue, have a great day.
Michal
