Entering to UCCE Field.Need Help
Muhammed Ashiq
Level 5
Level 5
Hi everyone,
Recently i got a job in contact center field,and i am fresher in contact center enterprise.
can anyone help , that i have no idea where to start.i had downloaded the solution and design guides and all,but as a fresher from where i have to start.
please....
i think somebody can help me because almost everyone faced the same problem when starting the career in contact center field.
thank you.
Sasikumar Divvela
Solution design guide is the best place to start.
1) go through different deployments (UCCE, PCCE, HCS, etc) . and try to understand  reference vs non-reference designs
2) refer virtualisation wiki . helps you to understand what kind of servers and how much resources you need, to deploy the contact center.
3) build a small lab setup using CVP,CCE,CCM, Finesse and simulate call and try to analyse the logs. you have lot of videos/support community threads which explains this part..
