R A Beginner
Beginner
Finesse going from Ready to Not Ready State during active call auto issue
we have faced an issue with some of our agents on finesse  .
some agent when they are going from ready to unready auto during active calls .
also this case happens when they are ready and no active calls.
be informed this happens to some agents not all ,and we set service parameters to let agent ready even after unanswered calls.
UCCX v 11.0
agent DN :7645
 use this below URL to download  these logs:
Thanks for your help
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Finesse going from Ready to Not Ready State during active call auto issue
The below is the reason why the agent was toggling between ready and not ready:
Evidence:
We see the agent in talking state :
0002106735: 10.1.20.250: Nov 20 2017 13:14:28.099 +0200: %CCBU_CTIMessageEventExecutor-0-6-DECODED_MESSAGE_FROM_CTI_SERVER: %[cti_message=CTIAgentStateEvent [skillGroupState=4 (TALKING), stateDuration=0, skillGroupNumber=-1, skillGroupPriority=0, agentState=4 (TALKING), eventReasonCode=0, numFltSkillGroups=0, CTIClientSignature=null, agentID=Seat-55, agentExtension=7645, agentInstrument=null, agentID_Long=Seat-55, duration=null, nextAgentState=3, fltSkillGroupNumberList=[], fltSkillGroupIDList=[], fltSkillGroupPriorityList=[], fltSkillGroupStateList=[]]CTIMessageBean [invokeID=null, msgID=30, timeTracker={"id":"AgentStateEvent","CTI_MSG_RECEIVED":1511176468099,"CTI_MSG_DISPATCH":1511176468099}, msgName=AgentStateEvent, deploymentType=CCX]][cti_response_time=0]: Decoded Message to Finesse from backend cti server
After the call is over, the agent selects not ready reason code 35(custom) and is now in not ready state :
0002107508: 10.1.20.250: Nov 20 2017 13:16:17.324 +0200: %CCBU_CTIMessageEventExecutor-0-6-DECODED_MESSAGE_FROM_CTI_SERVER: %[cti_message=CTIAgentStateEvent [skillGroupState=2 (NOT_READY), stateDuration=0, skillGroupNumber=-1, skillGroupPriority=0, agentState=2 (NOT_READY), eventReasonCode=35, numFltSkillGroups=0, CTIClientSignature=null, agentID=Seat-55, agentExtension=7645, agentInstrument=null, agentID_Long=Seat-55, duration=null, nextAgentState=null, fltSkillGroupNumberList=[], fltSkillGroupIDList=[], fltSkillGroupPriorityList=[], fltSkillGroupStateList=[]]CTIMessageBean [invokeID=null, msgID=30, timeTracker={"id":"AgentStateEvent","CTI_MSG_RECEIVED":1511176577324,"CTI_MSG_DISPATCH":1511176577324}, msgName=AgentStateEvent, deploymentType=CCX]][cti_response_time=0]: Decoded Message to Finesse from backend cti server
Now the agent manually changes the state from Not ready to Ready as we see a message sent from the client to webservice api in a form of a PUT request to change the state to ready:
0002117785: 10.1.20.250: Nov 20 2017 13:37:12.191 +0200: %CCBU_http-bio-8082-exec-17-6-API_REQUEST: %[REQUEST_URL=User/Seat-55][agent_id=Seat-55][requestId=93f5752f-119b-470d-87e7-b2d9082cb017][request_method=user.PUT][request_parameters= state:READY]: Request from client to webservice api
The agent then moves from Ready to Not Ready due to reason code 32759 = Phone crash/down/unregistered:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_9_0/user/guide/UCCX_BK_UE5BE47D_00_uccx-historical-reports-ug/UCCX_BK_UE5BE47D_00_uccx-historical-reports-ug_appendix_0111.html#UCCX_TP_P97E849F_00
PHONE_DOWN
Reason Code: 32759
State: Not Ready
The system issues this reason code if the agent’s phone crashes and that agent is placed in the unavailable state.
0002117870: 10.1.20.250: Nov 20 2017 13:37:40.706 +0200: %CCBU_CTIMessageEventExecutor-0-6-DECODED_MESSAGE_FROM_CTI_SERVER: %[cti_message=CTIAgentStateEvent [skillGroupState=2 (NOT_READY), stateDuration=0, skillGroupNumber=-1, skillGroupPriority=0, agentState=2 (NOT_READY), eventReasonCode=32759, numFltSkillGroups=0, CTIClientSignature=null, agentID=Seat-55, agentExtension=7645, agentInstrument=null, agentID_Long=Seat-55, duration=null, nextAgentState=null, fltSkillGroupNumberList=[], fltSkillGroupIDList=[], fltSkillGroupPriorityList=[], fltSkillGroupStateList=[]]CTIMessageBean [invokeID=null, msgID=30, timeTracker={"id":"AgentStateEvent","CTI_MSG_RECEIVED":1511177860705,"CTI_MSG_DISPATCH":1511177860706}, msgName=AgentStateEvent, deploymentType=CCX]][cti_response_time=1]: Decoded Message to Finesse from backend cti server
After toggling between ready and not ready due to phone down issue, the agent sends a logout request to the webservice api and logs out of finesse desktop:
0002118925: 10.1.20.250: Nov 20 2017 13:41:05.475 +0200: %CCBU_http-bio-8082-exec-4-6-API_REQUEST: %[REQUEST_URL=User/Seat-55][agent_id=Seat-55][requestId=a77d5a54-f621-4684-91a1-254d10535240][request_method=user.PUT][request_parameters= state:LOGOUT]: Request from client to webservice api
Conclusion :
Kindly check and make sure there are no network issues with the phone. You can check the Event viewer application and system logs from CUCM to track down the reason for the phone going down. The CCX engine logs is filled with 32759 events for this agent :
++++ Agent is in ready state  :
Nov 20 14:18:49.571 EET %MIVR-SS_RM-7-UNK:Rsrc: Seat-55 New State:AVAILABLE Old State:IN_SESSION Reason code:0
++++ System pushes the agent state from ready to not ready due to reason code 32759 as it suspects a phone crash/down situation
Nov 20 14:18:49.587 EET %MIVR-SS_RM-7-UNK:Rsrc: Seat-55 New State:UNAVAILABLE Old State:AVAILABLE Reason code:32759
+++ The system issues 32756 when the agent’s phone comes up after it has been through a Phone Down state however the agent still remains in not ready status
Nov 20 14:18:49.587 EET %MIVR-SS_RM-7-UNK:Rsrc: Seat-55 New State:UNAVAILABLE Old State:UNAVAILABLE Reason code:32756
Thanks and Regards,
Deepak Nair
5 REPLIES 5
Enthusiast
I have a couple of questions;
1. What's the exact version of CUCM and UCCX?
2. What type of device (i.e. 7965, 7975, 8841, etc.) do agents have? SCCP or SIP? Firmware version?
3. Are agents using unsupported phone actions/features (i.e. DND, iDivert, etc.)? Do they have access to them? Search for 'unsupported actions'...
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_0/release/docs/UCCX_BK_R7697E6E_00_release-notes-for-uccx-solution/UCCX_BK_R7697E6E_00_release-notes-for-uccx-solution_chapter_01.html
4. Are agents using unsupported configurations on the device; for example, busy trigger, same DN on multiple devices, etc.? Search the same doc for 'unsupported configurations'.
5. Do agents notice this problem when they move to another workstation/phone? Just make sure the agent's extension doesn't reside on multiple devices.
R A Beginner
Beginner
Hello Mark,
1. What's the exact version of CUCM and UCCX? CUCM 11.5 & UCCX 11.0
2. What type of device agents have? SCCP or SIP? Firmware version? Cisco Jabber Sip
3. Are agents using unsupported phone actions/features (i.e. DND, iDivert, etc.)? Do they have access to them? NO
4. Are agents using unsupported configurations on the device; for example, busy trigger, same DN on multiple devices, etc.? no
5. Do agents notice this problem when they move to another workstation/phone? after agent moved to another workstation r=this issue fixed but still happens randomly with other agents but not at all time
Enthusiast
Try running the Agent State Detail Report after one of these events and post the results. Please include a rough timeline when the agent experienced this problem. Also, check the dependency records within CUCM and make sure there's not multiple devices or user device profiles assigned to the agent(s). What type of device do agents have; device model?
Beginner
Hi Remon,
I had seen this issue happening with some of my Agents, please do try the following
In the UCCX GUI go to Subsystems -> Cisco Unified CM Telephony -> Cisco Unified CM Telephony Control Group and select the group you are using in your application.
At the bottom of the screen hit the "Show More..." button and fill in the correct Device Pool and DN Calling Search Space.  This modifies the CTI ports on the call manager that are used to transfer the calls to your agents.  Without the proper Pool and CS, the agent phones go into a "reserve/not ready' state.
I had followed the instructions as per this thread
Agent State go to Not Ready while in a call
Anoop
Evidence:
PHONE_DOWN
Reason Code: 32759
State: Not Ready
Conclusion :
Thanks and Regards,
Deepak Nair
Content for Community-Ad
August's Community Spotlight Awards
