Help with AA script.
garethpeart
Level 3
Level 3
I'm hoping someone out there is willing to help me! It's probably very simple for most of you, but I've been banging my head against this and getting nowhere.
All I want to do is to create a very simple Auto Attendant script that flows like this:
Wecome to our company,
If you know your party's extensions, you may dial it at any time
press 1 for x
press 2 for y
press 3 for z
press # To replay this menu.
Ufortunately, I haven't any programming experience and the most I normall do with UCCX is to change a paramater every now and again. Is there anyone willing to give me some fairly basic step-by-steps?
UCCX 8.0
Gareth,
There is a sample AA.aef script already available for you on the server that you can use as reference, here is more information on it:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_0/user/guide/uccx801gs_scripts.pdf
page 12-2
HTH,
Chris
Hi Gareth,
If you want to use a dial by extension what I normally use is a get digit string and switch step, something like this:
Start
Accept
Label MainMenu
optionDialed = get digit string
     -Succesfull
          callRedirect(optionDialed)
     -Timeout
          Switch (optionDialed)
               -press1
                    callRedirect (extension for x)
               -press2
                    callRedirect (extension for y)
               -press3
                    callRedirect (extension for z)
               -press#
                    Go to MainMenu
Terminate
End
Gareth,
page 12-2
HTH,
Chris
Thanks for all your replies!
I'm cheating at the moment (due to time constraints) and using Unity connection at this time. I'm playing around with the aa and other scripts so that I can use them when this happens again.
