02-20-2013 06:51 AM - edited 03-14-2019 11:16 AM
Can anyone advise what the interval times are for abandinterval1, abandinterval2, etc where it is defined and how I find out what time ir is set for?
I have a customer asking questions and i cannot find the actual time definition within the DBSchema doc..
Any & all help appreciated.
Sarah
02-20-2013 07:31 AM
then you are looking at the wrong document. It's there, for instance, check the Call_Type_Interval table.
For each CallType, there is a set of "Bucket Intervals" - these are basically intervals for measuring answer or abandon times. So you are able to see that a certain number of calls is answered within 2 seconds, another number of calls within 2 to 4 seconds etc.
Same applies for the number of abandoned calls, so using the above analogy, if the first bucket interval is 0-2 seconds, then you'll be able to see how many calls were abandoned within 2 seconds, and how many customers chose to hang up within 2-4 seconds, etc.
There's a subtle difference between AnsInterval and AbandInterval, though: the former resets when the CallType is changed in the script, the AbandInterval does not - it starts counting the seconds the moment the call is queued.
G.
02-20-2013 07:58 AM
Thanks Gergely, I am still not able to find where the times are set I looked all through the DBSchema, and could not find the time associated withe the bucjet intervals in the Call_Type_interval Table.
Can they be configured and if so where would it be done?
02-20-2013 08:20 AM
well, there's a default bucket interval called Default_Bucket_Intervals, when you created your CallTypes you propably set this default one to them.
Adding or modifying or removing them is possible usingthe ICM Configuration Manager. Check under List Tools > Bucket Intervals List. After creating one, you might want to set the desired CallType(s) with the new Bucket Interval.
G.
02-20-2013 08:25 AM
Thanks Gergely, I am just working on the reporting side of things, so haven't been involved in the system setup.
Apprecaite your help.
