09-27-2004 08:52 AM - edited 03-13-2019 10:28 PM
I have a lab environment with a MCS 7835 and I want to install ICM. The problem is that if I run the MCS hardware detection disks, they ask me for a product key and they install Windows 2000. Then, when we try to install ICM, but the setup process stops with the following error: "The NT Schedule service could not start" In fact, this service does not exist.
Maybe I am using the wrong Product key?
Are there CDs only for hardware detection (without OS installation?
Solved! Go to Solution.
10-08-2004 08:19 AM
Hi Raquel,
You can install ICM on an MCS server. You must load windows using the windows 2000 disc, cisco does not provide that for you.
Also, if you look at the ICM specs for processor and RAM, the only supported MCS servers are the 7835 and the 7845. My recommendation is to install the ICM on a cheaper server that meets the requirements posted here:
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_usage_guidelines_list.html
Starting on page 6 it gives hardware recommendations for each component of IPCC.
Matt
09-27-2004 08:59 AM
ICM does not use the Spirian win2000 load as callmanager and CRS servers.ICM uses normal windows 2000 .Also there are minimum service pack requirements before you can start installing ICM.Plus you need to install SQL 2000 or SQL 7 depending on which version of ICM you are installing.
I hope this helps.You can install ICM on any server where you can install windows 2000.Don't use the spirian load for it.ICM does not require any product keys.
Also as far as I know there are no hardware detection disks without OS disks .This is because all these disks are images.
Radhika
09-28-2004 03:09 AM
Thank you very much for your answer. So I can´t install ICM on my MCS platform, is that right?
Raquel
09-28-2004 05:42 AM
If on the MCS platform you can install normal windows ( not using callmanager or CRS disks) then you can install ICM on MCS platform.
Radhika
10-08-2004 08:19 AM
Hi Raquel,
Matt
