Issue with CVP, Script and Call Studio
Hi, when test the script via SIP Phone LinPhone only hear Sorry, We experience difficulties
I have a UCCE Packaged 10.5; I made a script with Call Studio very simple; only play Hello World with TTS in the Item 1 in Audio options.
The validate and deploy was successful. So I upload the holamundo.zip to CVP OAMP via VXML Applications and iwas successful also.
The configuration in the gateway XML is:
application
service new-call flash:bootstrap.vxml
service survivability flash:survivability.tcl
service holamundo flash:CVPSelfService.tcl
  param CVPPrimaryVXMLServer 10.10.5.114
  param CVPBackupVXMLServer 10.10.5.114
  param CVPSelfService-port 7000
  param CVPSelfService-app holamundo
And the dial-peer is:
dial-peer voice 1000 voip
session protocol sipv2
session transport tcp
incoming called-number .
codec g711ulaw
no vad
The application that performed the test is LinPhone where I listen sorry, we experience ......
I can debug thje script in Call Studio and was functionality correct; also verify with status.batch file and the application show Session Ending for holamundo application.
Any ideas for fix the problem?
Thanks so much.
Yes, it looks like you don't have a TTS server.
In Call Studio, there's an element in the Elements/Context/Application
Modifier.
Drag that in, click on its Settings tab.
Set default audio path to: /CVP/audio if you want to use VXMLServer's
tomcat to serve audio.
Then put any audio files you may have onto your
Cisco/CVP/VXMLServer/Tomcat/webapps/CVP/audio directory. The
installation comes with a few audio files in there already: like
helloworld_audio.wav
Note Tomcat is case-sensitive.
If you'd prefer to use IIS to serve up audio (and if it's running on
your CVP system) then it usually runs by default from *C:/inetpub/wwwroot/ *
Upon installing CVP, it usually puts system prompts into
C:/inetpub/www/en-us/sys
To use audio from the en-us/sys directory, then set the Default Audio
Path to http://IPaddress/en-ys/sys
10 Replies 10
janinegraves
Also, you can look in the Activity and Error logs for info about your
errors. They're on the CVP system under
CVP\VXMLServer\applications\appname\logs
Let me check the logs
Hi Janine, how are you?
After review this path:
C:\Cisco\CVP\VXMLServer\applications\holamundo\logs\ErrorLog
I see in the file error_log2016-06-08 the next:
10.10.5.114.1465399775092.13.holamundo,06/08/2016 09:29:35.138,A VoiceXML error occurred of type "error.com.cisco.media.resource.unavailable.tts"
10.10.5.114.1465399775092.13.holamundo,06/08/2016 09:29:35.138,An error has occurred.
10.10.5.114.1465399791612.14.holamundo,06/08/2016 09:29:51.659,A VoiceXML error occurred of type "error.com.cisco.media.resource.unavailable.tts"
10.10.5.114.1465399791612.14.holamundo,06/08/2016 09:29:51.659,An error has occurred.
10.10.5.114.1465399832843.15.holamundo,06/08/2016 09:30:32.890,A VoiceXML error occurred of type "error.com.cisco.media.resource.unavailable.tts"
10.10.5.114.1465399832843.15.holamundo,06/08/2016 09:30:32.890,An error has occurred.
Is necesary the server that you comment?
Sorry I am inexperienced in Call Studio and VXML.
Regards...
Modifier.
I test with other Script and work fine!!! But I need import other script but when I try, the import tool dont find any file.
The folder application have this folders:
admin
data
java
logs
What I need for import the script in call studio?
Thanks so much Janine..
You've imported a vxml server (runtime) version of the app.
You need to find the studio version of the app - it'll have folders
callflow and deploy.
There's no decompiler to convert from vxml server app to studio app
By the way, you can register to attend CVPD training remotely! It's with
me (live instructor) via webex and totally hands-on programming using my
remote student pods. Gets great reviews! Look for my website
trainingtheexperts.com/courses.html
Thanks, I send email for some questions. Regards
janinegraves
You need to have a Nuance TTS $Server to use the TTS feature. And you'd
need to configure the gateway to connect to it. If you haven't purchased
Nuance TTS, then use pre-recorded audio in the URI portion of the Audio
tab.
Hi Janine, how configure: pre-recorded audio in the URI portion of the Audio tab.
I need the media file server for this option?
Regards...
