05-27-2013 11:46 PM - edited 03-14-2019 11:47 AM
I want to check number of Max attempt done by Dialer to connect a Phone, can yo u please guide which table exactly refer this?
w r using SIP Dialer and in configuration, we have configured 3 Max Attempts
Hina
Solved! Go to Solution.
05-28-2013 12:52 AM
there are several ways:
1. (preferred): use the Dialer_Detail view of the HDS database, looking up the number and counting the rows, e.g.
SELECT COUNT(*) AS [attempts], Phone FROM
You may want to use a WHERE clause to filter out rows by the CampaignID and/or Date etc.
2. (usable): try to figure out the name of the dialing list table in the BA database (on the Logger A server).
DL_
This table actually contains the number of calls, see CallsMadeToZone1 and/or CallsMadeToZone2 - some limitations apply.
G.
05-28-2013 01:03 AM
You can tell by the CallResult code. The CallStatus would also be M (max attempts reached) or C (closed).
For the CallResult codes, see the "Outbound Option Guide for Cisco Unified Contact Center Enterprise and Hosted" for your particular ICM version.
G.
05-28-2013 12:52 AM
DL_
G.
05-28-2013 01:00 AM
Thank you very much .. can you please tell one more thing, how can we check that the number is attempted 3 times but didnt receive or answered by customer ?
05-28-2013 01:03 AM
G.
05-28-2013 04:40 AM
I used like this
select * from t_Dialer_Detail where CallStatusZone1 = 'M'
select COUNT(*) AS [attempts], Phone from t_Dialer_Detail where CallStatusZone1 = 'M'
GROUP BY Phone
