Need help about ICM script 10.5(1)
Using ICM Script 10.5(1), I try to create dynamic condition node by concatenate
By trying these steps
1. concatenate("PQ.", "PQ_NONGLUCK", ".LogOn > 0") and fill into If Node, it always return false
2. use custom function by bypass like customfunction1(concatenate("PQ.", "PQ_NONGLUCK", ".LogOn > 0")) and fill into If Node it always return false
3. I use If function by using If(concatenate("PQ.", "PQ_NONGLUCK", ".LogOn > 0"), 1, 0) and fill into Set Variable Node, it always return 0
Please help.
1 ACCEPTED SOLUTION
9 REPLIES 9
jkotelly@cisco.com
You need to use the "Dynamic IF node" feature for Precision Queues which was a 10.5 feature. It is described in the “Dynamic Formula” section on pg. 151 here: http://wwwin-eng.cisco.com/Eng/CCBU/Common/Projects/Unified_CCE_Release_10.5/Customer_Docs/UCCE_BK_S09E5905_00_scripting-and-media-routing-guide.pdf@8. There is a different syntax required to do this as described in the document.
thanks,
Jim
I may have mis-understood your requirement based on the concatenate() being used. You should just be able to (in the Formula editor) put the equation "PQ.PQ_NONGLUCK.LoggedOn > 0" in the If node itself. Note the "LoggedOn" variable spelling.
thanks,
jim
Hi Jim,
I had try but unfortunately it return false as in attached Figure.
Hi Jirayu,
Try removing the quotes and just set the expression into the node directly.
Jim
Hi Jim,
As I said actually I try to substitute the quote with concatenate string for create a dynamic text like concatenate("PQ.", "PQ_NONGLUCK", ".LoggedOn > 0") when I replace "PQ_NONGLUCK" with ECC variable.
Jirayu
Hi Jim,
I try to access the provided link (Dynamic IF Node) but look like it's broken.
Jirayu
Hi Jim,
It's working by use this below syntac
PQ.{Call.user.preferredPQ}.LoggedOn > 0 in IF node
Jirayu
Dear Jim,
Thank you
Jirayu
Content for Community-Ad
