09-13-2008 10:50 AM - edited 03-14-2019 02:53 AM
hi. Our organization wants to buy IPCC
Enterprise Lab Edition. Is there any lab edition available? How to buy lab edition. pls hlep us. If i want to set up lab for our company what is the requirement, what are the software , hardware we have to buy. How to buy?
Bob
Solved! Go to Solution.
09-14-2008 08:28 PM
> 1. What are the s/w needs to order for Lab edition .Found in Cisco site below product available for ICM 7.0.can I go ahead order this. Or can I go with what you recommended
ICM or IPCC? What are you planning on connecting it to?
If you are going with IPCC, do you have non-production licenses for Call Manager and IPIVR? If ICM, do you have an ACD to connect it to?
> 2.I have limited server spare server , I am planning to install in VM ware .Can you pls suggest. If you have any information how to install in VMware.
An ICM or IPCC Sprawler will install on either a single server (any hardware) or on VM Ware.
>3.We already having CCM on MCS ,If i go with Sprawler which Minimum configuration MCS h/w required for 7.0
ICM/IPCC does not perform HW checking. As such, it does not require MCS HW - it will install on anything if you are using it for non-production / lab use.
Production use requires MCS or equivalent, otherwise you will not be supported.
>4.Is there latest version of ICM available for LAB?
Yes. You would install the base version (7.0 or 7.5), then patch appropriately.
>5. Any cost different in IPCE-NPSENT-CP?
> IPCE-NPSENT-CP and ICME-NPSENT-EC which less one.
What you are connecting it to will dictate which one you should purchase - see above.
>6.What are the advantage if I go with Non-production Suite ATP Partners
Are you a customer or partner? If you are a customer, you will not be able to order the partner codes anyway.
Corey.
09-14-2008 04:23 PM
Yes. Are you a Cisco partner or customer?
If you aer a customer, then order the following product:
IPCE-NPSENT-EC
CC ENT Non-Production Suite Customer
If you are an ATP partner, then order one of the following products (use the DART code if you order via DART):
IPCE-NPSENT-CP
CC ENT Non-production Suite ATP Partners
IPCE-NPSENT-DART=
CC ENT Non-Production Suite ATP Partners
Corey.
09-14-2008 04:36 PM
Hi Corey. Thank you very much for your help.It is realy helpful to select the product. is there any configuration docs available.Please let me know
thanks
Gem
09-14-2008 04:41 PM
You can find the config guides here: http://www.cisco.com/en/US/products/sw/custcosw/ps1844/tsd_products_support_configure.html
You can find the installation guides here:
http://www.cisco.com/en/US/products/sw/custcosw/ps1844/tsd_products_support_install_and_upgrade.html
Links to all documentation can be found here: http://www.cisco.com/en/US/products/sw/custcosw/ps1844/tsd_products_support_series_home.html
Corey.
09-14-2008 08:16 PM
Thanks for Update .
1.ICME-NPSENT-EC : ICM Enterprise Non-Production Suite End
2.ICME-MEDIA700-K9 ICM ENTERPRISE MEDIAKIT RELEASE 7.0
IPCE-NPSENT-CP
IPCE-NPSENT-DART=
09-14-2008 08:28 PM
Corey.
09-15-2008 07:52 PM
Thanks for prompt reply.
Let me check the compatibility list for ICM 7.x for CCM 4.x.
Bob
09-23-2008 05:16 PM
Planning to order
Verified in compatibility list and found for 7.0 x,below list require .All will available with lab edition kit ?
Going to use 4.2x ,While order CCM we got IPCX 4.0 std 5 seat .
2. IP IVR- 4.0(5a) , 4.0(4) , 4.0(3), 3.5(4)
3.CVP -4.0(1) SR1, 3.1 SR2
4,ICM 7.0
5. CTI desktop 4.7
6. E-Mail Manager Option 5.0
7.Web Collaboration Option 5.0
8.Communications Manager 4.2 requires CAD 7.0(1) or greater.
If it ICM 7.0 can I upgrade to 7.5 in sprawler setup
Or Which train of ICM good , we want do some upgrade and test it ,Can i go with which version where can i upgrade 7.x to 7.5
09-23-2008 06:39 PM
As I mentioned above, if you are using it for IPCC, then you need:
IPCE-NPSENT-EC
If you are using it for TDM, then you need:
These are no longer sold as they are EOSL.
Yes.
7.5(x) is a new set of installation media, and will install on the versions outlined in the Release Notes - see http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/icm_enterprise/icm_enterprise_7_5/release/notes/icm75rlsnts.pdf or http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/icm_enterprise/icm_enterprise_7_5/release/notes/icm752_rn.pdf
"Direct upgrades are allowed only from Release 7.x (at least 7.0SR4) to Release 7.5."
Corey.
09-23-2008 09:35 PM
Thanks Corey.
Can you please guide me which documents to refer to get knowledge in IPCCX and IPCC Ent from basic .
I am new to IPCCX and IPCC Ent.I have hands on experience in CCM
09-23-2008 09:57 PM
You are probably best off going on a bootcamp - the IPCCE / UCCE course is a 2 week bootcamp that covers off ICM, IPIVR, CCM, and how they are all linked. The IPCCX / UCCX courses are typically a week long.
If you are determined to learn from scratch, then I would suggest the lab guides that have been discussed in other threads on here, and review the SRNDs (as a starting point).
Corey.
09-25-2008 09:14 AM
Thanks Corey
