Need sample code for participant states
beozer
I am trying to use the dialog object to identify its (or more like its participant's) state. The generic state is easy to fetch but what I am after is a (participant's) state like 'HELD' or 'WRAP_UP'
Please provide a short sample code?
Thank you in advance.
dekwan
Unfortunately, per DevNet's support guidelines, providing sample code is out of the scope of DevNet Developer support.
I would suggest taking a look at the Finesse JavaScript Library API documentation, specifically at the Dialog object.
In the Dialog object, there is a getParticipants() method that retrieves the list of participants in the Dialog. From there, you would just need to get the state of the participant.
I hope this helps.
Thanx,
Denise
dekwan
I hope this helps.
Thanx,
Denise
