PCCE 10.0 system validation
I am getting the following error on system validation of DS. And this process is needed for HDS and for PCCE we don't install HDS (as its optional). Can i ignore this error ? or is it fixed with a ES? Currently we are using Unified CCE Version 10.0.1.0.0.1660
Vinay K M
Follow the docwiki link for further clarification , its notified as bug   and there is a workaround
http://docwiki.cisco.com/wiki/Data_Server_Operational_Status_Rule_Error_for_Logger_Replication_Process
Geevarghese Cheria
Hi Senthil,
   After checking our knoweldge base for a similar issue i was able to find the following solution.
you can turn on the replicator process on both sides and even though there is not an external HDS. it will sit in a dormant state and that alert will go away. Otherwise, if you choose to leave the replicator process off the alert will continue but a benign alert.
Require validation services to be enabled regardless of the presence of an external hds.
Thanks and Regards,
Geevarghese
Vinay K M
