Hello Everyone
I understand that the Post Call Survey need to configure the Unified CVP Call Server for Post Call Survey via CVP Operations Console by typing https://<OAMP_server_IP>:9443/oamp.
refer to this document :
If we want to do the survey via CTI Route Point on CUCM, can we do the Post Call Survey via CTI Route Point on UCM ?
If it can do, how to implement the Post Call Survey via CTI Route Point ?
Thank you in advance.
Solved! Go to Solution.
It is not possible to enable post call survey for CTI route print. you should route the call to CVP and enable post call survey.
