11-13-2018 04:23 AM - edited 03-14-2019 06:37 PM
Hello Everyone
I understand that the Post Call Survey need to configure the Unified CVP Call Server for Post Call Survey via CVP Operations Console by typing https://<OAMP_server_IP>:9443/oamp.
refer to this document :
If we want to do the survey via CTI Route Point on CUCM, can we do the Post Call Survey via CTI Route Point on UCM ?
If it can do, how to implement the Post Call Survey via CTI Route Point ?
Thank you in advance.
Solved! Go to Solution.
11-20-2018 09:00 PM
It is not possible to enable post call survey for CTI route print. you should route the call to CVP and enable post call survey.
11-20-2018 09:00 PM
11-20-2018 10:01 PM
