tauqeer.nasir1
Enthusiast
Play Audio while waiting for a process to be completed in Decision Element
Dear,
I am trying to play music on hold while an application is processing on the backend. I am using the following properties
Here is my application of which I am using simple class and set 100 seconds delay
in the ABC class, I am simply using sleep for 100 seconds. Logically application will play music on hold configured in root settings. But unfortunately, It is not playing anything and not even error.
8 REPLIES 8
janinegraves
Rising star
what version of CVP do you have? And are you using the VVB? I think
there's a bug in 11.5...
I am using 11.5 and using VVB as well.
Yes, there's a bug... not sure if there's a patch yet. You can look. Try
using an Audio element just prior to your delay, and put the fetchaudio
and its URI in the settings tab, it might work from the element level.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd98241/?referring_site=bugquickviewclick
Bug Search Tool
Bug Search <https://bst.cloudapps.cisco.com/bugsearch/>
CSCvd98241
Help  |FeedbackFeedback
VVB Null Pointer Exception with FetchAudio
CSCvd98241
Look like it's been patched. I don't have patch access but see the screenshot below.bug.JPG
Thank you for the response. Can you please guide me how can I do this by using audio element?
At the bottom of the Settings tab there's an area called VoiceXML
Properties. Just enter Name and Value there. It's probably best to
configure both fetchaudio and fetchtimeout there.
You'll need to put something in the Audio tab of the Audio element. If
you don't want to play anything, then point to Cisco's silence.wav file
- you can DeSelect the checkbox for use Default Audio Path, and enter
http://ipaddress/en-us/sys/silence.wav
Hi Janine,
Thank you for your response. I am currently using CVP 11.5(1) and this release is not affected but still facing the same issue.
Try setting the fetchaudio and fetchtimeout in an Audio element just
prior to your web service call.
Settings tab: VoiceXML Property
Name: fetchtimeout  Value: 20s
Name: fetchaudio     Value: http://ip/en-us/sys/something.wav
Audio  tab:  Deselect checkbox for UseRecordedAudio
URI: http://ip/en-us/sys/silence.wav
or
URI:  http://ip/en-us/app/pleaseHoldWhileWeLookThisUp.wav
Content for Community-Ad
