02-14-2006 09:09 AM - edited 03-13-2019 11:30 PM
I have a prompt setup to play a wav file that is longer than 2 minutes. When it reaches 2 minutes it dumps the call. When I use a wav file under 2 minutes everything is fine. Is this a limitation someone else has run into? I have not found information on the required prompt format other than use the ulaw ccitt standard.
Bruce
02-14-2006 09:41 AM
No issues whatsoever. I have used much longer wav files. Are you using IPCCX or IPCCEnterprise. If you are using IPCCE, check your Network VRU script configuration - the timeout value. It is possible that your script is set to timeout after 2 minutes.
If you are using IPCCX, I have not experienced any issues with playing long wav files.
02-14-2006 10:14 AM
Sanjeev,
Thanks for the suggestion, but that did not help. I bumped the timer up to 360 and it still dumped the call at exactly 120 seconds.
Bruce
02-14-2006 10:57 AM
Sanjeev,
You were correct! I was setting it on the wrong script like a idiot.
Thanks again for the help
Bruce
