Poll: Should Studio include the enhanced Audio Element?
janinegraves
Rising star
Rising star
PLEASE REPLY if you would like Cisco to include the enhanced audio element as an out of the box element in Studio.
The Enhanced Audio element includes the following Settings:
1) Play Audio to completion before continuing (so you can catch exceptions if audio files are missing)
2) Flush the DTMF input buffer
With this element, you'll no longer have to 'guess' which audio elements might be causing 404 exceptions. No longer will you need to disable barge in to flush the dtmf input buffer. No longer have to wonder why the activity log seems to show the CVP_Subd_Return taking 8 seconds to complete, etc, etc.
I would love to see this in Studio!!!
Thanks, Janine
6 Replies 6
shaun.milliken
Beginner
Beginner
I agree!
Shaun
vincent.zheng
Enthusiast
Enthusiast
I also agree !!
Vincent
Gerry O'Rourke
Rising star
Rising star
Janine,
Using IIS logs you can see which wav files are causing the 404s.
But not which application caused it.
So I 100% agree that we should be able to see this error in CVP Studio activity logs and error logs.
i.e. so you can be sure its the application you are debugging which is causing the 404 and exactly where it has the issue.
So the enhancement would be for CVP VXML server to log correctly the 404 error details.
This would be better than having CVP studio audio element having to play out audio before continuing.
i.e. as this could have a negative performance impact or delay in future elements.
But if 404 error logs is not be possible, then I 100% agree, this should be a non default option.
Summary of Enhancement
Log the 404 error logs with the wav file URL in CVP Studio application logs.
Have an option (checkbox) in the play media element to clear DTMF buffer (unchecked by default)
Have an option (checkbox) to play out media before preceeding to next element (unchecked by default).
Note: Last feature should only be added if CVP cannot log wav file errors correctly (which they do not do today)
Gerry
I agree as well!
Denis
Beginner
Beginner
Would be great to have it!
Denis
Ryan Hilfers
Beginner
Beginner
+1, ability to block on audio is a must have!
Recognize Your Peers
