01-29-2015 03:52 AM - edited 03-14-2019 02:22 PM
I have a customer with UCCX 8.5(1)SU4 Enhanced which uses CAD version 8.5.1.417.
When I run PostInstall.exe I get the message below:
Warning: if PostInstall is run as a domain administrator you will not be able to set up RASCAL replication later
I am using a domain admin account and am trying to get PostInstall running so that I can enable the virtual environment setting.
Can I ignore this warning or should I use another type of account?
Solved! Go to Solution.
01-30-2015 04:51 AM
Yeah - from a 'client' (which is the only place this exists on 8+) you don't have any sort of replication to configure. I'm guessing it's picking up that you are a domain admin and has some legacy code that would have picked up that scenario on a CCX server where you have added it to an AD domain (generally 'bad practice' in Cisco's view) and are configuring it with a domain admin.
On a client you pretty much have just the setting you want for term services, and the SPAN NIC selection. Nothing that can break the server...
Aaron
01-30-2015 04:51 AM
Aaron
