Hello
When captured in a string variable the calling number (calling number in Get Call contact Ingo palette of CRS Editor only accept string variable), and then I search in a field of SQL database that is defined as variable char therefore can not be defined as type string there, running the debugger I get error the routine of Java.
How do I solve this problem?
Omar
