06-06-2008 01:59 PM - edited 03-14-2019 02:21 AM
Hi all,
I have IPCC Express 5.0.2_SR01_Build053 here, together with Callmanager 5.1.3.3000-5.
I have a problem logging in an to the Agent Desktop or the IP phone agent when using extension mobility.
When a EM profile is used, I get an error message that the device needs to be assigned to the RM JTAPI user. When I configure the phone directly with an Agent extension, it works fine.
The association of the device to the RM JTAPI user is made and double-checked. Do I need to do something else? I cannot assign the UDPs to this user because UDPs cannot be assigned to Application users.
Any ideas?
Thanks in advance
Jörg
Solved! Go to Solution.
06-08-2008 09:08 AM
Hi Jorg
The RM JTAPI user needs to be associated to the physical devices (SEPs), not the EM profiles.
Otherwise, the most common error I've seen is when the EM User's end user account doesn't have 'Enable use of CTI' checked on their account. This is different to previous 4.x CCM versions...
Whilst all phones have CTI enabled on the phone config page by default, users don't, so when an EM user logs in to a phone it disables CTI until they log out again.
So check the EM users's CTI check box, and try again.
Aaron
Please rate helpful posts...
06-08-2008 09:08 AM
Hi Jorg
Aaron
06-10-2008 07:59 AM
Aaron,
this exactly was the problem. The Enable-CTI flag was not ticked for the user.
Thanks for your help!
Jörg
