Purge problem Logger
rhobab
One of my loggers has stopped purging some of the tables in particular the TCD and RCD tables. looking at the history I find the following error.
RegOpenKeyEx() returned error 2, 'The system cannot find the file specified.'
Msg 22001, Level 1, State 1
(0 row(s) affected)"
Any ideas?
Victor
Where there any reacent changes to the logger?  Seems like it might be an issue with SQL.  Can you log in locally and bring up MS SQL and run a simple query?
david
Hello David
Thanks for the reply. These loggers are separated by a WAN connection that went down simultaneosly fro both public and private networks. Initially I tried sincronising the loggers using ICMDBA but for some reason with no success so I hado to copy the LoggerA database and restore on the LoggerB side. What was causing the problem with the purge is that the stored procedure in SQL was pointing to LoggerA registry setting. Modifying it to LoggerB solved the problem. Curiously only some of the tables were not being purged while others were.
Thanks all the same.
Victor
