Quality and WorkForce Management ACD data and some problems
gokcesuzen
Beginner
Beginner
I installed the Quality / Adv Quality Mgt. and than i installed workforce management services. I have access panels each service no problem. But, I constantly getting the following mail from WFO and I do not know how to solve
WFM2001
Message:
The Capture Service is failing to capture ACD data.
Action: Contact technical support.
Other problem; I can't see anything about my agents, teams or etc. when i open WFO web management page or Quality Manager Administration.
For example on WFO web management page, left pane, Agents menu, i can't see my CXX agents.
Last one, i need to WFO and Qualit Management Recording using documentation (how to use both programs ?)
Thx....
Documentation is here : http://www.cisco.com/en/US/products/ps8293/tsd_products_support_series_home.html
It would appear you haven't set up the SQL connection as directed in chapter 3 of the install guide.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Recognize Your Peers
