Walkthrough Wednesdays
584
keanej
Participant
Quality Management 10.5.1 to 11.5.1 SR6 Upgrade Problem
Upgraded Workforce Optimizer Quality Management Call Recording or WFO-QM
from 10.5.1 SR6  to 11.5.1 SR6
Problem: Calls not recording, QM2014 - did not receive packets for at least 15 seconds for a call on device
The Upgrade Procedure was pretty straightforward -
Uninstall 10.5.1 SR6
Uninstall 10.5.1
Turn off VM
Turn on VM
Install 11.5.1 SR6 - Select one Signaling Method, select all base options.
Install.
We are using Server Recording, using one adapter on the box thats listening.
The Recording seems to work for about 15-20 minutes and then all calls have no RTP stream.
I have tried using PostInstall/Tools/Download&Install JTAPI
I have checked PostInstall/Tools/ChooseMonitorAdapter
I have checked PostInstall/TelephonyGroups ... all good.
I have checked PostInstall/Tools/Start Local Services to ensure all services are started in correct order etc
Everything looks perfect on the configuration...
Any help appreciated
2 REPLIES 2
csrlima
Participant
Hi , didi you solve your problem?
I am doing same upgrade and i need some advices.
A lot the issues were around Server Recording V Network Recording.
I get the inpression server recording wasnt proplerly tested - I was told the 'vast majority' are using network recording
Turns out we needed to go an extra version, to get the server recording working.
Content for Community-Ad
Spotlight Awards 2021
