01-11-2007 03:37 AM - edited 03-14-2019 12:25 AM
Hi,all
I enocuntered one problem when I installed the System IPCC 7.0. My Media Kit is 7.0(0)B. I
followed the document to install and it was OK at first. There was one error when I should configure the IPCC Machine Initialization. When I created the IPCC Root, I created the Facility next. I pressed the creat button then I entered the name of Facility. At this time, One error displayed. It said that Failed to correctly initialize service -set service group in the Local Administrator Group. You can see the attachment for the more detail information. I have reinstalled the system, but the problem happened again. Could everyone give me some suggestion?
Any errort will be appreciated. Thank you!
01-17-2007 11:09 AM
09-26-2007 04:10 AM
I am installing the IPCC 7.0 and have the same problem as you. Have you solved it? Could you advise me...?
Michal
