11-04-2019 08:58 AM
Hi Team,
I am facing one issue in Record with Confirmation element. we have the requirement like once customer record the information and then we need to playback for confirmation press 1 and not confirm press 2 .
after the record with confirmation element i placed the decision element for pass the string press 1 for confirmation and press 2 for not confirm.
If i press 1 it went to the proper flow which i linked from decision element . then if i press 2 for not confirm
it not go to next which i linked from decision element, its playing same element itself Record with confirmation element
Decision element logic here
11-04-2019 09:00 AM
11-05-2019 10:35 AM
So you want to record their audio response, then if they press 1 to confirm then you want to play it back, but if they press 2 then you do not want to play it back?
11-06-2019 07:31 PM
11-07-2019 09:04 AM
Sounds you have the right idea on how to format the logic. It sounds like the problem is in the details of your Call Studio nodes.
Check your logs, is the logic hitting your option 2 code? If it is then you'll need to look at your option 2 nodes for any problems as to why it's not working the way you'd like.
