Remote Monitoring in IPCC 5
vinayjaiswal
Level 3
Level 3
Dear All,
We have IPCCX 5.0 with premium license. The issue which I am facing is of Remote Monitoring. I am unable to monitor the logged in agents.I authenticate using the remote user id. As soon as i press the extn of the agent to be monitored i get a promt saying agent not logged,even though the agent is logged. It has been working fine for some time, but currently it is playing the same prompt. I have checked the configuration and restarted the the server.
Any comment would be highly appreciated.
Vinay
Tanner Ezell
Level 4
Level 4
Sounds like you are using a script, can you provide it for us to look over?
Does the monitoring work when using the CSD software?
Tanner Ezell www.ctilogic.com
Hi Thanks for replying. We are using the default script. Please find attached the same.
