Running reports from Logger vs AWHDS
lohjintiam
Level 4
Level 4
Hi all,
I'm trying to evaluate the impact of running reports from both Logger + AWHDS vs AWHDS alone.
Is there any reporting data which is available on the Logger only but not populated to the AWHDS?
Thanks!
-JT-
Sunil_Vs1
If your HDS AW is DDS-HDS type(Detail Data Server), you get all the reports from your HDS AW. DDS will include tables such as RCD and TCD records. These records are not available in your HDS AW if it's not DDS AW type.
It's also not recommended to run complex queries from the loggers.
-Sunil
Hi Sunil,
Yup i'm having AW HDS DDS. So all real time and historical reports can be run out of this?
How about outbound / dialer campaign reports?
Thanks!
-JT-
Yes, you should have real time reports.
I believe you also see outbound / dialer campaign reports. Look for tables such as Campaign.
-Sunil
