Silent monitoring - Without Supervisor Desktop
Landontod
Is it possible to dial into an application via a phone and silent monitor an agent? Example, training class with a conference phone turned on and listening to an agent for an hour.
6 Replies 6
Gergely Szabo
I am not aware of any application included with UCCE.
However, it's relatively easy to build such an application, since CTI OS supports - or, at least, exposes - API calls to start silent monitoring from a third party application. It's even easier with Gen3 phones since they support CUCM-based silent monitoring using their built in bridge (BiB).
G.
Is there a sample code snippet that outlines which Cisco APIs and subsequent API calls are needed to instantiate a silent monitor?
Is there an RSM (Remote Silent Monitoring) product from Cisco?
Geoff
KennethLentz
I'm particularly interested in the socket based protocol that is available in UCCX.
hmm what about the remote monitoring for UCCX....there you need to create an application and use the rmon.aef system script? Maybe that can work for you
Gabriel.
Pranjol Saikia
Level 4
Level 4
Checkout the doc if it helps.
https://supportforums.cisco.com/document/12296686/silent-monitoring-cisco-call-manager-without-need-uccx
You can do silent monitoring using a application service configured in the Cisco IP Phone
