Walkthrough Wednesdays
962
gchiarapa_value
Beginner
SIP Outbound calls - 404 not found
Hi Guys!
We are facing some problems with outbound calls. When an agent makes a call, the call is established and in the middle of the call appears a SIP message 404 not found and the call drop. In extension display, appears a message dialing.
Call Flow:
Extension > CUCM > CUBE > CUSP > ISP.
3 REPLIES 3
Jinto Alakkal
Beginner
Hi Can you post,
the output of "debug ccsip messages" and also the "debug voip dialpeer all" separately from the CUBE
Thanks!
Jinto.
Please, see attached files.
Call-ID: 14571F0E-C81411E8-AF0DB5A3-4D72A66F
Call-ID: 9F77C469-C81311E8-A22DB5A3-4D72A66F
Hi There, I was away just went through the traces could you please post the CUBE configuration have you tested whether the inbound and outbound dial peers are matching properly ?
Content for Community-Ad
Spotlight Awards 2021
