SIP Proxy Guide.
Ritesh Desai
Hi folks,
am new to CUSP SIP Proxy. any video / guide on how to configure SIP Proxy. I found a video which is helpful to less extent. I've CUSP module which is installed on 2951 Router. CUSP version is 9.1.4.
Please suggest.
thanks & regards,
Ritesh Desai.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Chris Deren
What is the CUSP going to be used for? UCCE deployment?
Hi Chris,
It will be used for PCCE deployment.
thanks & regards,
Ritesh Desai.
Ritesh,
Here are a few links for configuring CUSP
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/unified-sip-proxy/116252-configure-cusp-00.html#anc5
++ How to enable traces on CUSP ++
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/unified-sip-proxy/118827-technote-cusp-00.html
Please rate all useful posts
Hi Ayodeji,
Thanks. I will study and update you.
regards,
Ritesh Desai.
