07-17-2013 01:25 PM - edited 03-14-2019 12:05 PM
Is it ok to install SQL Server Management Studio on the same server that runs UCCX 7.0(2)? Aside from a mandatory reboot, it seems like a low-impact install - just can't find anything about it in the documentation.
Marino
07-19-2013 01:33 AM
technically, nothing can prevent you from doing that.
Cisco says you should not and may risk losing support.
G.
Log in to Community
