07-05-2012 10:50 PM - edited 03-14-2019 10:10 AM
Hey Guys,
I'm looking for a way of slowing down the reading speed of a Float variable when using the the prompt shortcuts: N[FloatVariable].
Can anyone comment if this is possible or if not if this can be achieved through other means?
G
Solved! Go to Solution.
07-06-2012 02:50 AM
What you are calling TTS is actually just a directory full of pre-recorded words and sounds.
True TTS would be like a Nuance integration with a Premium license. And I'm positive you can control the speed and pitch with Nuance. That's can get expensive though.
At any rate, if you are playing back a dollar amount, the best you can do is break up the audio yourself, and play each token with a customizeable delay inbetween.
Here's what I mean:
Play Prompt (N[10] + DP[500] + SP[gen/currency/usd] + DP[500] +sp[gen/currency/and] + DP[500] +N[3] + DP[500] +sp[gen/currency/cents])
Of course it's not just that easy. You'll just need to script two things:
1. You'll need to script a solution which takes a floating point number (with a floor and ceiling) and converts it to its many parts, separating each part with a delay prompt.
2. Figure out where the system prompts are. E.g., "Dollars", "and", and "cents" (or if localizing, those localized prompts E.g., "Pounds", "and", "pence")
That's the best I got. Happy scripting!
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
07-06-2012 02:50 AM
Here's what I mean:
Anthony Holloway
07-08-2012 05:48 PM
Thanks Anthony, Seems excessive just to slow the reading speed but can only work with what the software can achieve right.
Might put in a feature request and see what happens
Thanks again, I better start scripting..
G
07-08-2012 06:56 PM
No problem. And you're right. We work with what we have. Good luck.
