10-01-2015 10:51 PM - edited 03-14-2019 03:16 PM
Hello. I'm looking for clues as to why I can't login to the CTI OS client. I get the message "Error [12005]Login could not be performed - Possible causes are Invalid Instrument; Media Termination Problem or other CM issue" and have tried everything I've found on Google about the issue without success. I'm trying to trace what's going on but I'm not sure where and what I need to trace. Anyone know what I should trace?
Thanks!
10-01-2015 11:47 PM
Here is the link for enabling trace.
http://www.cisco.com/c/en/us/support/docs/customer-collaboration/unified-contact-center-enterprise/116165-trouble-ucce-trace-00.html#anc6
10-02-2015 12:14 AM
I have version 7.0.0. Neither of those registry keys seem to log anything. Here's what I have:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Cisco Systems, Inc.]
"CTIOS Tracing"=dword:00000fff
[HKEY_CURRENT_USER\Software\Cisco Systems\CTIOS\Logging]
"TraceMask"=dword:00000fff
I used Sysinternals procmon to see if it was writing a log file anywhere besides what's mentioned in your link and didn't see anything.
Any other ideas? Is there something I can enable on CUCM or the PG that will help? At this point I'm not really sure where it's failing (CM or the PG)!
10-02-2015 01:14 AM
Try Un-associate/Re-associate the Device from the PG User.
10-02-2015 04:23 AM
I tried this many times before and just now again. This doesn't seem to help my situation like it does with other posts I've found. I've also made sure the settings are correct in device targets and have even completely removed the device resync'ed JTAPI (on UCCX - not sure if this had any chance of helping).
All the things I've tried from searching aren't working, that's why I'm trying to find out what tracing I can do to troubleshoot.
10-05-2015 05:38 AM
look for C:\users\<user>\ for CTIOS client log.
if you dont find there, search out with string "ctiosclientlog" in widows, you must find it located somewhere.
