UCCE 10.5 teamadmin doesn't work
korolevec
It is a UCCE 10.5
After upgrade the link http://<PG>:8088/teamadmin/main.cda doesn't work.
But I want change workflow team for my agents, how I can do that?
Thank you in advance.
Kartik Bhatia
Isnt it suposed to be login.cda like:
http://<IP>:8088/teamadmin/login.cda
Else Install CDA software - login - n from top menu there click on Desktop Workflow Admin or something like that menu option.
Kartik Bhatia
Thnx,
login.cda also doesn't work.
When I try select Desktop Administrator - Side A (or Side B) from menu CDA I see the browser window with  link http:// IP :8088/teamadmin/main.cda and message "404 - File or directory not found"
I have a 10.0 UCCE - and I tried and got login.cda
try
http://<IP address of UCCE Peripheral GW>:8088/teamadmin/login.cda
got to be a Tomcat thing - try on the PG box itself?
And on your Agent - do you see see them in Partial service by any chance?
If you can - You might wanna stop all CAD services on the PG and start them again
Kartik Bhatia
I just realised you have alrdt tried
ignore that comment
