05-06-2021 08:48 AM
Hello Mentors,
I need your help to set up the UCCE Home Lab.
Hardware was not a concern, Can run upto 10 VM's with 8GB of RAM each.
I have gone through the below link:
I looking for a complete solution demo (Side A and Side B)
CVP
UCCE Core Components
CUCM
Finesse
CUIC
Enterprise Chat and Email
I am planning to have below configuration:
1. Progger ( fully duplexed)
2. Two CVP combo servers ( Call server, vxml server and media server for both side A and B
3. A single AWHDS server
4. Single finesse server
5. A single CUCM Publisher
6. A Single CUSP on vmware
Solved! Go to Solution.
06-08-2021 06:02 AM
Yes, you can set up simplex or duplex based on your Hardware resource availability.
Setup simplex mode with Sprawler
1 VM – ICM ( Router+Logger+AWD+PG+CTI+Dialer) all in one VM
1 VM – CVP ( CVP Oamp, CVP Call+Vxml server)
1 VM – CUCM
1 VM – CUIC
1 VM – Finesse
1 VM – VVB
For Duplex setup
2 VM – ICM ( Router+Logger) Rogger in one VM
2 VM – ICM ( AW)
2 VM – ICM ( PG)
1 VM – CUCM
1 VM – CUIC
1 VM – Finesse
1 VM – VVB
Ram.S
05-06-2021 09:32 AM
What help do you need?
05-10-2021 12:55 AM
I want to know what will be the configuration of VM (cores, memory, nic) and how many total VM will be needed for this setup.
Or Please suggest a better setup than this for a lab environment.
06-06-2021 11:55 PM
06-08-2021 06:02 AM
1 VM – CUCM
1 VM – CUIC
1 VM – Finesse
1 VM – VVB
For Duplex setup
2 VM – ICM ( AW)
2 VM – ICM ( PG)
1 VM – CUCM
1 VM – CUIC
1 VM – Finesse
1 VM – VVB
Ram.S
06-08-2021 07:49 AM - edited 06-08-2021 07:52 AM
06-08-2021 11:20 PM
For UCCE there is no system inventory hardware validation, So we can increase or decrease the hardware peripheral based on system performance
For LAB setup Database consideration for the log set as 1 GB max and Data 25 GB ( Logger +AW+HDS)
Ram.S
06-09-2021 12:27 AM
Thank you for your input.
Can you please guide me on, how to download the OVA/Software for UCCE Component and licensing requirement.
Pranjal
06-09-2021 11:23 PM
You should have Cisco CCO ID to download Cisco software and OVA etc.
For Lab, we can test inbound calls for 30 days with an evaluation period.
Ram.S
06-10-2021 02:02 AM
Thank you, For your help, I will keep updating this thread with the Lab progress.
