UCCX 10.5 script not showing up for Debug
lmrscheff
Beginner
Beginner
When I select a script to debug, none of the scripts show up in the drop down list.  Not sure what is going on??
rossporubski
Participant
Participant
How are you able to select a script if none of the scripts show up?
Correction:  When I try to select a script to debug, none of the scripts show up in the drop down list.
A few questions to preface the issue.
When did you upgrade or is this a new install?
Are you logged into Script Editor with admin authentication or annonymously logged in?
When was the last time you tried performing a reactive debug and scripts were visible?
Have you made any changes since then?
https://supportforums.cisco.com/discussion/11292101/uccx-851-crs-editor-reactive-debug
Recognize Your Peers
