10-09-2020 04:46 AM
Hello all,
I am facing an issue in ASR auto attendant. When I call I can hear only the welcome prompt and then an error prompt stating as "currently facing system problem try again later", not sure what am missing. Nuance services are UP so I don't find any issues in service, anyone faced any issue like this?
10-09-2020 07:06 AM
Usually the system problems message plays when your script throws an exception. These exceptions are in the MIVR logs, but it sounds like this is new and you could just as easily reactive debug the script to both see: which step is causing the exception and what it's trying to tell you. Do you know how to reactive debug?
10-09-2020 07:55 AM
10-09-2020 11:04 AM
Hmm, based on that, I'm not too sure. Did you put your ASR media group in your Trigger?
10-10-2020 03:10 AM
Yes, I have added the ASR media group in my Trigger.
10-21-2020 08:48 PM
After changing the IP in "Nuance\V.X\mrcp\nuance-resources.txt" the issue got solved.
11-26-2020 10:42 AM
Hi, I am experiencing the same issue with my Nuance deployment when debugging my script. Does anyone know where this configuration is within the Nuance server configuration? ("Nuance\V.X\mrcp\nuance-resources.txt"), so I can resolve my issue?
Steve
