uccx 12.5 integration of a telephone ivr with banking system or external database.
yiosepvaldes
There is some guide or documentation where I can support or someone who can guide me in knowing the protocols or programming languages with which I can integrate a traditional ivr script to a general banking network for example to make a query or block a product.
that uccx version 12 can be integrated natively or on its own without depending on third-party applications or platforms, for example without web server between the uccx and the banking database.
Hey Y.
It all depends of what kind of integration your banking system has.
For one of my customer (also a bank) i use the MAKE REST Call step to integrate directly to they banking system. This is returning JSON  that i then make my routing strategy from (if the customer has account (and have many ), apply for a loan etc.).
I make the call with a user pin and they number (in the body of my rest call) so I validate them to the banking system.
You can read more of the MAKE REST CALL step her
UCCX REST/JSON Post - Page 2 - Cisco Community
The rest step can alse return XML or what you want - depends of you service you are calling
You can also integrate directly thru SQL if that what you want instead.
For both of these you don't need a middleware server, both integrate directly from the UCCX server.
What kind of integration does your banking system has ?
Thomas
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Thomas G. J.
Thank you very much for your prompt reply. I see that you have good practical experience in the subject, I would like to be able to support me with you in the basic guide of where I can read or study the subject.
It is my first practical business case that I will be able to carry out.
The question you ask me about the banking system, I am in the next few days to get a session with the final client, to see a part of what they currently have, how they integrate it into the platform they want to replace; and thus be able to answer the question and understand a little more the depth of the scope in which I am going to enter. For the next week I hope to have a more concrete answer about what language or type of programming socket they use, and later to be able to evaluate what options or paths I can take to achieve the objectives.
Thanks a lot.
For the Database integration you need premium agents, and for using the MAKE REST CALL you only need an enhanced license
