07-25-2011 01:13 AM - edited 03-14-2019 08:16 AM
Hi, one of the users i added supervisor capability but doest appear team on select team section at cisco supervisor desktop program.
I did give authority to user like other supervisor user. On the resource list the user have supervisor indicator.
What could be the problem ?
Best, thanks.
Solved! Go to Solution.
07-25-2011 02:25 PM
As well as allocating 'Supervisor' rights, you must also link the Supervisor to the teams you want the Supervisor to see in 'Teams' configuration in AppAdmin (RmCm config page, then click 'Teams'). By default, they see no teams, so the drop down list in CSD is empty.
Aaron
Please rate helpful posts...
07-25-2011 05:46 AM
Hello Baris.
You can try to do a Directory Services Resync
https://supportforums.cisco.com/docs/DOC-9162
Please rate this post if was helpful
Walter Solano
07-25-2011 02:25 PM
Aaron
07-29-2011 12:34 AM
Problem solved,
Thanks Aaron.
