2121
Beginner
UCCX 8.5.1 CAD Client Configuration tool installation problem
I have get errors when I try to installing CAD Client Configuration tool. I am using windows 7 x64 ent.
First error        Second error
Everyone's tags (7)
4 REPLIES 4
Highlighted
Beginner
I had the same problem. After restart of UCCX the problem was not seen anymore.
Engager
Hi Murat,
Just as an alternative use any Windows XP box and perfrom this CAD client Configuration tool run successfully, so that it won't  block any other CAD\CSD getting upgraded.
Just my thoughts.
Anand
Pls rate helpful posts !!
Beginner
Hi all,
I have the same issue.
I tried to restart the uccx cluster but it didn't solve the problem.
Did you found the solution ?
regards,
JF
Beginner
Problem was gone after restarting UCCX. This was the solution in my case.
regards
br
Content for Community-Ad
August's Community Spotlight Awards
