AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
450
Beginner
uccx 8.5: supervisor capability problem
Hi, one of the users i added supervisor capability but does not appear the supervisor availables on the teams.
What could be the problem ?
Thanks a lot.
Alexis Munoz
4 REPLIES 4
Engager
Hi Alexis,
Please check if he is already associated as the Primary\Secondary Supervisor to any exisitng teams.
Anand
Please rate helpful posts !!
Beginner
Hi Anand
i have checked this association, but the user does not still appear either as available supervisor or Primary\Secondary Supervisor
What configuration should apply on the system to achieve this??... i already assigned to the user the supervisor capability, what else am i missing on the system?
I appreciate the help.
Alexis
Highlighted
Engager
Hi Alexis,
If you go to the Supervisor Capability Management page, you are able to see this use as the Supervisor. (Please attach the snapshot).
If you have already associted this Superviosr as Primary\Secondary Supervisor to any of the existing teams , than it will not be available for any new teams, you need to de-associate it from the earlier team to associate with the New team.
Hope this helps.
Anand
Engager
Any updates on this ?
Anand
Content for Community-Ad
August's Community Spotlight Awards
