UCCX 802 INSTALLATION HELP REQUIRED
usmanghani255
Hi fellows
i want to setup UCCX802 on 8gb ram 64 bit Window 7 operating system for lab purpose.
At his stage i am not sure whether i can do that or not. I just want to setup UCCX 802 so that i can practice a lot for my exam. i have the demo license and i want you please help me, How i can setup UCCX 802.
I need step by step instructions about what do i need inorder to setup UCCX 802. Thanks
Jonathan Schulenberg
Install VMware Workstation (or server), use the OVA to build a CUCM and CCX virtual machine, and install the software from bootable media. Note that what you can download from Cisco.com is NOT bootable. You'll need an Intel processor; AMD is known not to work.
Once the software is installed you can use the Installation Guide and Administration Guides for CCX for step-by-step instructions.
Please remember to rate helpful responses and identify helpful or correct answers.
