UCCX ASR problem
Anton Rybak
We have UCCX version 12 and ASR/TTS server VoiceNavigator. I m used standard script for testing ASR and TTS. I also created MRCP ASR provider, dialog and server, MRCP TTS server and provider. All services status "IN SERVICE". When i tried to test script, i used default dialog group in trigger configuration. Script is working and TTS too, but ASR not even starting. I tried to use MRCP ASR Dialog group in trigger configuration, but call not reaching script at all, so reactive debegging not working and when i try to call trigger number i hear only fast busy tones. Help please find solution with ASR, thank you.
Jonathan Schulenberg
Unfortunately, Nuance remains the only supported vendor: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/uccxcompat12_0_1.html#ASR_and_TTS
Of course, you could try pulling logs from one or both platforms to see if you can spot an issue. Hopefully this is a lab scenario where you can tinker and learn; I would have heartburn about a production deployment knowing Cisco won’t support it.
Attached log with failed calls.
Jonathan,
please, could you check last log? Call even not reaching script with ASR and TTS on UCCX. Thank you.
Anton Rybak
4003072: Jun 27 17:19:17.181 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.executor.impl.ExecutorStubImpl.RequestImpl Route Connection=[614050:Internal:1/(P1-cti_manager_new_1) GCID=(1,338156)->ACTIVE]->OFFERED, reason=1, Event= CallCtlConnOfferedEv 614050:Internal:1, cause=100, metacode=129, isMaster=true
4003073: Jun 27 17:19:17.181 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.jtapi.TAPIPortGroup Just before getUniqueID
4003074: Jun 27 17:19:17.181 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.jtapi.TAPIPortGroup Originator Protocol Call Ref = 00000000000528EC012346FD00000000
4003075: Jun 27 17:19:17.181 GMT+300 %MIVR-SS_CM-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.rmcm.CallContact RmCm contact -1[null] .setAppContact(1322) from null
4003076: Jun 27 17:19:17.181 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.jtapi.CallImpl Call.received() JTAPICallContact[id=1322,implId=338156/1,state=STATE_RECEIVED_IDX,inbound=true,App name=VoiceNavigator,task=null,session=null,seq num=-1,cn=614050,dn=614050,cgn=5475,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=614050,route=RP[num=614050],OrigProtocolCallRef=00000000000528EC012346FD00000000,DestProtocolCallRef=null,TP=null
4003077: Jun 27 17:19:17.182 GMT+300 %MIVR-SS_CM-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.rmcm.ICDContactAdapter ICDContactAdapter 1182 : ContactSessionChanged received for App FW contact 1322, iefSourceContact is 17115372 [338156/1] (988)
4003078: Jun 27 17:19:17.182 GMT+300 %MIVR-SS_CM-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.rmcm.ICDContactAdapter Ignoring contactSessionChanged because either the new or old session is null
4003079: Jun 27 17:19:17.183 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_RTR_EVENTS-37-0-CONTACT_RECEIVED] com.cisco.wf.subsystems.jtapi.CallImpl TAPIPortGroup::CallImpl:getReportingPropeorty - Get Property : 1
4003080: Jun 27 17:19:17.183 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_RTR_EVENTS-37-0-CONTACT_RECEIVED] com.cisco.wf.subsystems.jtapi.CallImpl TAPIPortGroup::CallImpl:getReportingPropeorty - IVR OB Call. Found "OBIVRCALL" in the contact context : false
4003081: Jun 27 17:19:17.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.OutboundMgrMsgProcessor OutboundMgrMsgProcessor:Processing msg: OutboundCSQIterationMsg: csqID: 3 ,dialerType: PREVIEW_DIALER
4003082: Jun 27 17:19:17.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.CSQPreviewOutboundInfo OutboundContactInfo:getNumberContactsToCall() for csqID:3 :0
4003083: Jun 27 17:19:17.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.PreviewDialer PreviewDialer:sendAgentReservationMsgToRMCM() csqid:3 ,#Total active resources in csq:0.0 ,#CSQ allocation %:100 ,#active:0.0, #active-working:0, #Number of Available resources:0, #lic_left:25, #contacts:0
4003084: Jun 27 17:19:18.687 GMT+300 %MIVR-SS_RM-7-UNK: [MIVR_SS_RM_RmMsgProcessor-107-0-RmMsgProcessor] com.cisco.wf.subsystems.rmcm.RsrcMgrMsgProcessor Processing msg: CTISnapshotDeviceReqMsg CTIMgrTPCCReqMsg Socket:Socket[addr=192.168.204.2,port=56630,localport=12028] invokeID:41692, peripheralID: 1, deviceIDType: 76, agentInstrument: 5618
4003085: Jun 27 17:19:18.688 GMT+300 %MIVR-ICD_CTI-7-UNK: [MIVR_ICD_CTI_SERVER-94-1-outboundMsgQ] com.cisco.wf.subsystems.ctiserver.CSOutboundMsgProcessor OutboundMsgProcessor: got message: { SNAPSHOT_DEVICE_CONF }
4003086: Jun 27 17:19:18.688 GMT+300 %MIVR-ICD_CTI-7-UNK: [MIVR_ICD_CTI_SERVER-94-1-outboundMsgQ] com.cisco.wf.subsystems.ctiserver.CSOutboundMsgProcessor OutboundMessageprocessor : sending msg : { length=-1 type=SNAPSHOT_DEVICE_CONF,invokeId=41692 numCalls=0 to socket: Socket[addr=192.168.204.2,port=56630,localport=12028]
4003087: Jun 27 17:19:18.688 GMT+300 %MIVR-ICD_CTI-7-UNK: [MIVR_ICD_CTI_SOCKET-145-54925-PROCESS_CTI_MGR_RESPONSE] com.cisco.wf.subsystems.ctiserver.MsgHandler MsgHandler : Sent : { SNAPSHOT_DEVICE_CONF to Socket[addr=192.168.204.2,port=56630,localport=12028] }
4003088: Jun 27 17:19:18.689 GMT+300 %MIVR-SS_RM-7-UNK: [MIVR_SS_RM_RmMsgProcessor-107-0-RmMsgProcessor] com.cisco.wf.subsystems.rmcm.RsrcMgrMsgProcessor Processing msg: CTISnapshotDeviceReqMsg CTIMgrTPCCReqMsg Socket:Socket[addr=192.168.204.11,port=50476,localport=12028] invokeID:48338, peripheralID: 1, deviceIDType: 76, agentInstrument: 5618
4003089: Jun 27 17:19:18.689 GMT+300 %MIVR-ICD_CTI-7-UNK: [MIVR_ICD_CTI_SERVER-94-1-outboundMsgQ] com.cisco.wf.subsystems.ctiserver.CSOutboundMsgProcessor OutboundMsgProcessor: got message: { SNAPSHOT_DEVICE_CONF }
4003090: Jun 27 17:19:18.689 GMT+300 %MIVR-ICD_CTI-7-UNK: [MIVR_ICD_CTI_SERVER-94-1-outboundMsgQ] com.cisco.wf.subsystems.ctiserver.CSOutboundMsgProcessor OutboundMessageprocessor : sending msg : { length=-1 type=SNAPSHOT_DEVICE_CONF,invokeId=48338 numCalls=0 to socket: Socket[addr=192.168.204.11,port=50476,localport=12028]
4003091: Jun 27 17:19:18.690 GMT+300 %MIVR-ICD_CTI-7-UNK: [MIVR_ICD_CTI_SOCKET-139-56594-PROCESS_CTI_MGR_RESPONSE] com.cisco.wf.subsystems.ctiserver.MsgHandler MsgHandler : Sent : { SNAPSHOT_DEVICE_CONF to Socket[addr=192.168.204.11,port=50476,localport=12028] }
4003092: Jun 27 17:19:18.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.OutboundMgrMsgProcessor OutboundMgrMsgProcessor:Processing msg: OutboundCSQIterationMsg: csqID: 3 ,dialerType: PREVIEW_DIALER
4003093: Jun 27 17:19:18.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.CSQPreviewOutboundInfo OutboundContactInfo:getNumberContactsToCall() for csqID:3 :0
4003094: Jun 27 17:19:18.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.PreviewDialer PreviewDialer:sendAgentReservationMsgToRMCM() csqid:3 ,#Total active resources in csq:0.0 ,#CSQ allocation %:100 ,#active:0.0, #active-working:0, #Number of Available resources:0, #lic_left:25, #contacts:0
4003095: Jun 27 17:19:19.730 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.OutboundMgrMsgProcessor OutboundMgrMsgProcessor:Processing msg: OutboundCSQIterationMsg: csqID: 3 ,dialerType: PREVIEW_DIALER
4003096: Jun 27 17:19:19.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.CSQPreviewOutboundInfo OutboundContactInfo:getNumberContactsToCall() for csqID:3 :0
4003097: Jun 27 17:19:19.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.PreviewDialer PreviewDialer:sendAgentReservationMsgToRMCM() csqid:3 ,#Total active resources in csq:0.0 ,#CSQ allocation %:100 ,#active:0.0, #active-working:0, #Number of Available resources:0, #lic_left:25, #contacts:0
4003098: Jun 27 17:19:20.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.OutboundMgrMsgProcessor OutboundMgrMsgProcessor:Processing msg: OutboundCSQIterationMsg: csqID: 3 ,dialerType: PREVIEW_DIALER
4003099: Jun 27 17:19:20.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.CSQPreviewOutboundInfo OutboundContactInfo:getNumberContactsToCall() for csqID:3 :0
4003100: Jun 27 17:19:20.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.PreviewDialer PreviewDialer:sendAgentReservationMsgToRMCM() csqid:3 ,#Total active resources in csq:0.0 ,#CSQ allocation %:100 ,#active:0.0, #active-working:0, #Number of Available resources:0, #lic_left:25, #contacts:0
4003101: Jun 27 17:19:20.777 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_RECOVERY_0_-44-0-RUN] com.cisco.wf.subsystems.jtapi.RecoveryThread Running CTI Port recovery 'MIVR_SS_TEL_RECOVERY_0_-44-0' @ 1561645160777
4003102: Jun 27 17:19:20.777 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_RECOVERY_0_-44-0-RUN] com.cisco.wf.subsystems.jtapi.RecoveryThread ... CTI Port recovery 'MIVR_SS_TEL_RECOVERY_0_-44-0' @ 1561645160777 done.
4003103: Jun 27 17:19:21.200 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_EXE-40-12318-CONN_DISCONNECTED] com.cisco.executor.impl.ExecutorStubImpl.RequestImpl RP[num=614050], conn=[614050:Internal:1/(P1-cti_manager_new_1) GCID=(1,338156)->INVALID]->DISCONNECTED, event=CallCtlConnDisconnectedEv 614050:Internal:1, cause=Other: 17[17], meta=META_CALL_ENDING[132]
4003104: Jun 27 17:19:21.200 GMT+300 %MIVR-SS_TEL-5-CTIPG_ROUTE_EVENT: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.executor.impl.ExecutorStubImpl.RequestImpl CTI Port Group route event: Route Session=[614050:Internal:1/(P1-cti_manager_new_1) GCID=(1,338156)->INVALID]->DISCONNECTED,Route Address=614050,Failure reason=CTI accept timer expires after 4019 ms, end route connection,Exception=com.cisco.lang.InterruptedException: No idle channels available in group 'VoiceNavigatorASR Group #2'; nested exception is:
com.cisco.lang.sync.AttemptInterruptedException: interrupted while allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))]; nested exception is:
com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR)]; nested exception is:
com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003105: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION:com.cisco.lang.InterruptedException: No idle channels available in group 'VoiceNavigatorASR Group #2'; nested exception is:
4003106: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptInterruptedException: interrupted while allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
4003107: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
4003108: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))]; nested exception is:
4003109: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR)]; nested exception is:
4003110: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003111: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:981)
4003112: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:706)
4003113: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:400)
4003114: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:354)
4003115: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:427)
4003116: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003117: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003118: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003119: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003120: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003121: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003122: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: nested stack trace is:
4003123: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptInterruptedException: interrupted while allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
4003124: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
4003125: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))]; nested exception is:
4003126: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR)]; nested exception is:
4003127: Jun 27 17:19:21.201 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003128: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync.attempt(MultiSync.java:401)
4003129: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitCollection.attempt(PermitCollection.java:422)
4003130: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:941)
4003131: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:706)
4003132: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:400)
4003133: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:354)
4003134: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:427)
4003135: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003136: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003137: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003138: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003139: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003140: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003141: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: nested stack trace is:
4003142: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [(('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))) & 'Cisco CTI Port Group #5']; nested exception is:
4003143: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))]; nested exception is:
4003144: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR)]; nested exception is:
4003145: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003146: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync$RequesterImpl.unacquireAll(MultiSync.java:700)
4003147: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync.attempt(MultiSync.java:381)
4003148: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitCollection.attempt(PermitCollection.java:422)
4003149: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:941)
4003150: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:706)
4003151: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:400)
4003152: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:354)
4003153: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:427)
4003154: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003155: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003156: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003157: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003158: Jun 27 17:19:21.202 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003159: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003160: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: nested stack trace is:
4003161: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from [('VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR))]; nested exception is:
4003162: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR)]; nested exception is:
4003163: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003164: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.ExclusiveAsync$RequesterImpl.unacquireAll(ExclusiveAsync.java:689)
4003165: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.ExclusiveAsync.unacquire(ExclusiveAsync.java:331)
4003166: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync$RequesterImpl.unacquireAll(MultiSync.java:677)
4003167: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync.attempt(MultiSync.java:381)
4003168: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitCollection.attempt(PermitCollection.java:422)
4003169: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:941)
4003170: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:706)
4003171: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:400)
4003172: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:354)
4003173: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:427)
4003174: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003175: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003176: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003177: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003178: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003179: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003180: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: nested stack trace is:
4003181: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2' & ('Cisco Unified CCX Ports' & 'ASR Ports' & VoiceNavigatorASR)]; nested exception is:
4003182: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003183: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiAsync$RequesterImpl.unacquireAll(MultiAsync.java:672)
4003184: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiAsync.unacquire(MultiAsync.java:338)
4003185: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.ExclusiveAsync$RequesterImpl.unacquireAll(ExclusiveAsync.java:659)
4003186: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.ExclusiveAsync.unacquire(ExclusiveAsync.java:331)
4003187: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync$RequesterImpl.unacquireAll(MultiSync.java:677)
4003188: Jun 27 17:19:21.203 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync.attempt(MultiSync.java:381)
4003189: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitCollection.attempt(PermitCollection.java:422)
4003190: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:941)
4003191: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:706)
4003192: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:400)
4003193: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:354)
4003194: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:427)
4003195: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003196: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003197: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003198: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003199: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003200: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003201: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: nested stack trace is:
4003202: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: com.cisco.lang.sync.AttemptTimeoutException: timed out allocating from ['VoiceNavigatorASR Group #2']
4003203: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.AbstractAsync.unacquire(AbstractAsync.java:190)
4003204: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitSet$RequesterWrapper.unacquire(PermitSet.java:659)
4003205: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitSet.unacquire(PermitSet.java:220)
4003206: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitCollection$Collector.unacquire(PermitCollection.java:202)
4003207: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.AbstractAsync.unacquire(AbstractAsync.java:176)
4003208: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiAsync$RequesterImpl.unacquireAll(MultiAsync.java:649)
4003209: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiAsync.unacquire(MultiAsync.java:338)
4003210: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.ExclusiveAsync$RequesterImpl.unacquireAll(ExclusiveAsync.java:659)
4003211: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.ExclusiveAsync.unacquire(ExclusiveAsync.java:331)
4003212: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync$RequesterImpl.unacquireAll(MultiSync.java:677)
4003213: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.MultiSync.attempt(MultiSync.java:381)
4003214: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.lang.sync.PermitCollection.attempt(PermitCollection.java:422)
4003215: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:941)
4003216: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:706)
4003217: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:400)
4003218: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.channel.Group.getIdleChannels(Group.java:354)
4003219: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:427)
4003220: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003221: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003222: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003223: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003224: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003225: Jun 27 17:19:21.204 GMT+300 %MIVR-SS_TEL-5-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003226: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.executor.impl.ExecutorStubImpl.RequestImpl Route Connection: [614050:Internal:1/(P1-cti_manager_new_1) GCID=(1,338156)->INVALID]->DISCONNECTED, Routing Exception: CTIERR_UNSPECIFIED=0x0::Unspecified error: Exception=com.cisco.jtapi.InvalidStateExceptionImpl: Did not meet pre-conditions.
4003227: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION:com.cisco.jtapi.InvalidStateExceptionImpl: Did not meet pre-conditions.
4003228: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.jtapi.ConnectionImpl.reject(CTQF)
4003229: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.wf.subsystems.jtapi.RouteCallObserver$1.run(RouteCallObserver.java:577)
4003230: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:690)
4003231: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:486)
4003232: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:762)
4003233: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:768)
4003234: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.executor.impl.PooledExecutorStubImpl$1$WorkerImpl.run(PooledExecutorStubImpl.java:99)
4003235: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:853)
4003236: Jun 27 17:19:21.205 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.jtapi.CallImpl CallID:1322 MediaId:338156/1 is removed from call session mapping in Session[id=001-0xaf16b1d74,parent=null,active=true,state=SESSION_IN_USE,time=1561645157181], result:true
4003237: Jun 27 17:19:21.207 GMT+300 %MIVR-SS_TEL-7-UNK: [MIVR_SS_TEL_TPG_ROUTE_EXE-41-878-ROUTE_CALL_EV] com.cisco.wf.subsystems.jtapi.CallImpl Call.rejected(REMOTE_TIMEOUT) JTAPICallContact[id=1322,implId=338156/1,state=STATE_REJECTED_IDX,inbound=true,App name=VoiceNavigator,task=null,session=47000001908,seq num=0,cn=614050,dn=614050,cgn=5475,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=614050,route=RP[num=614050],OrigProtocolCallRef=00000000000528EC012346FD00000000,DestProtocolCallRef=null,TP=null
4003238: Jun 27 17:19:21.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.OutboundMgrMsgProcessor OutboundMgrMsgProcessor:Processing msg: OutboundCSQIterationMsg: csqID: 3 ,dialerType: PREVIEW_DIALER
4003239: Jun 27 17:19:21.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.CSQPreviewOutboundInfo OutboundContactInfo:getNumberContactsToCall() for csqID:3 :0
4003240: Jun 27 17:19:21.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.PreviewDialer PreviewDialer:sendAgentReservationMsgToRMCM() csqid:3 ,#Total active resources in csq:0.0 ,#CSQ allocation %:100 ,#active:0.0, #active-working:0, #Number of Available resources:0, #lic_left:25, #contacts:0
4003241: Jun 27 17:19:22.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.OutboundMgrMsgProcessor OutboundMgrMsgProcessor:Processing msg: OutboundCSQIterationMsg: csqID: 3 ,dialerType: PREVIEW_DIALER
4003242: Jun 27 17:19:22.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.CSQPreviewOutboundInfo OutboundContactInfo:getNumberContactsToCall() for csqID:3 :0
4003243: Jun 27 17:19:22.731 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_OutboundMgrMsgProcessor-64-0-OutboundMgrMsgProcessor] com.cisco.wf.subsystems.outbound.PreviewDialer PreviewDialer:sendAgentReservationMsgToRMCM() csqid:3 ,#Total active resources in csq:0.0 ,#CSQ allocation %:100 ,#active:0.0, #active-working:0, #Number of Available resources:0, #lic_left:25, #contacts:0
4003244: Jun 27 17:19:23.081 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_ReadContactsThread-142-0-ReadContactsThread] com.cisco.wf.subsystems.outbound.ReadContactsThread ReadContactsThread: # of active campaigns =1
4003245: Jun 27 17:19:23.081 GMT+300 %MIVR-SS_OB-7-UNK: [MIVR_SS_OB_ReadContactsThread-142-0-ReadContactsThread] com.cisco.wf.subsystems.outbound.ReadContactsThread ReadContactsThread: Campaigns without contacts in memory:[11]
4003246: Jun 27 17:19:23.081 GMT+300 %MIVR-CFG_MGR-7-UNK: [MIVR_SS_OB_ReadContactsThread-142-0-ReadContactsThread] com.cisco.config.impl.ConfigManagerImpl getAccessor(ConfigQuery):Try to get the default accessor
4003247: Jun 27 17:19:23.081 GMT+300 %MIVR-CFG_MGR-7-UNK: [MIVR_SS_OB_ReadContactsThread-142-0-ReadContactsThread] com.cisco.config.impl.dbaccessor.DBAccessor DBAccessor.get(query))
