Highlighted
Rising star
UCCX Finesse and AQM Integration to invoke start call Recording when agent login in USING AQM API
Hi ,
 our Client Requirement is to start and stop the recording when agent login into Cisco Finesse and stop when he logs out.
We have UCCX 10.6 and AQM 10.5.
Summary of Current Configuration
    :- AQM is successfully recording calls when workflow is set to Record.
    :- Now to invoke the recording only when Agent logs in , first i set the AQM workflow to "Do Not Record" for all calls
    :- Secondly created a Workflow in Cisco Finesse , to send the API Control command when call is answered. I followed the procedure in this guide
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/workforce_optimization/qm_10x/reference/guide/qm-integration-guide-cad-finesse-105.pdf FInesse Workflow
    :- But it is not working
Any One tried this particular solution , what am i missing.
4 REPLIES 4
Contributor
Hi Harris-I haven't worked on
Hi Harris-
I haven't worked on AQM 10.5, but do you see the commands in the Recording logs on AQM server? That might yield some useful information.
DJ
Enthusiast
Hi! I've tried and I believe
Hi! I've tried and I believe your Finesse Workflow is correct.
The trick is that on AQM you need to have your WFO Workflow Allowing to Record all calls.
Then to exclude all calls from being recorded, you can use the Inclusion List and make * for Exclude all Patterns for being recorded. Then your Finesse Workflow will work:
1) All calls are sent to AQM, but are not recorded because of the Excluded Pattern = *
2) Finesse Workflow only has the power to overwrite the Inclusion List configuration
3) Finesse Workflow cannot overwrite the AQM Workflow configuration.
Hope it helps,
Rui
Beginner
Hi HARIS_HUSSAIN
Hi HARIS_HUSSAIN
have you fixed your issue yet  ?
i have same request from our client .
many thanks if you can share it your solutions .
thanks
Justin
Enthusiast
Hi Justin,
Hi Justin,
I put an attach with the configs that need to be done, regarding the bullets I've described previously:
Hope it helps,
Rui
Content for Community-Ad
August's Community Spotlight Awards
