ā02-10-2013 05:03 AM - edited ā03-14-2019 11:14 AM
Dears,
I create UCCX auto attandend its working fine from internal calls can reached to ext after recording. But External Calls can reached to direct line recording but after that when press 1 , 2 the call cannot reached to Ext. can any one help me to solve it.
Solved! Go to Solution.
ā02-10-2013 08:52 AM
Please post your GW configuration and let us know what protocol are you using, i.e. SIP, H323, MGCP?
Chris
ā02-10-2013 05:08 AM
Hi Khalid Khan,
Please check the below thread,
https://supportforums.cisco.com/thread/2028843
Anand
Chris
ā02-11-2013 05:35 AM
Dear Chirs,
I have add all configuration of GW. there is to much Dial peer But for UCCX we are using 7337 i Bold that config.
please check and give me full salution I will be thanks full to you,
we have two GW and i upload all conf for both GWs.
________________________________________________________________________________
sh run
Building configuration...
dial-peer voice 7337 voip
description -Incomming-Test
destination-pattern 7337
--More-- signaling forward unconditional
session protocol sipv2
session target ipv4:
session transport tcp
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Note : All IP in this GW are Private IPs.
ā02-12-2013 10:57 PM
Mr. Chris Deren
can u check my cnfig please.
ā02-13-2013 07:05 AM
Add incoming called-number 7337 to dial-peer 7337.
Also, it is using H323 DTMF method on sip dial-peer, you need to use sip DTMF method such as dtmf-relay rtp-nte.
HTH,
Chris
ā02-14-2013 05:15 AM
Thanks Dear
Its Working fine .
