UCCX. How External Calls Reached to IVR Then Ext
khalid_ijk
Dears,
I create UCCX auto attandend  its working fine from internal calls can reached to ext after recording. But External Calls can reached to direct line recording but after that when press 1 , 2 the call cannot reached to Ext. can any one help me to solve it.
Chris Deren
Please post your GW configuration and let us know what protocol are you using, i.e. SIP, H323, MGCP?
Chris
6 Replies 6
anchoudh
Level 9
Level 9
Hi Khalid Khan,
Please check the below thread,
https://supportforums.cisco.com/thread/2028843
Anand
Chris Deren
Chris
Dear Chirs,
I have add all configuration of GW. there is to much Dial peer But for UCCX we are using 7337 i Bold that config.
please check and give me full salution I will be thanks full to you,
we have two GW and i upload all conf for both GWs.
________________________________________________________________________________
sh run
Building configuration...
dial-peer voice 7337 voip
description -Incomming-Test
destination-pattern 7337
--More--                            signaling forward unconditional
session protocol sipv2
session target ipv4:
session transport tcp
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Note : All  IP in this GW are Private IPs.
Mr. Chris Deren
can u check my cnfig please.
Add incoming called-number 7337 to dial-peer 7337.
Also, it is using H323 DTMF method on sip dial-peer, you need to use sip DTMF method such as  dtmf-relay rtp-nte.
HTH,
Chris
Thanks Dear
Its Working fine .
