08-11-2013 08:06 AM - edited 03-14-2019 12:13 PM
Hi All,
I am new to scripting and I created a scrpt for a group, everything is working fine but when the call comes to queue and the agent deosn't pick the call, the
caller hear "
I have attached the script, any help is appreciated.
Thanks in advance.
09-15-2018 02:53 PM
I am facing this issue but after restarting the server , it disappeared but now it happened again .
09-17-2018 03:32 AM
Ensure you open the script and then run a validation step to ensure nothing is missing within the script. If you are running a reactive debug and you don’t see anything pop up when you initiate the call, it means it would be something from the initial part of the script. More specifically anything above your Holiday check. Since you are carrying over script from old CCX to 9.X, just check for steps that are no longer valid in CCX 9
07-05-2017 12:06 AM
In addition,it can also happen if your script is invalid due to some missing parameter or prompt etc.Try to validate the script, you will get the idea and fix the problem.If validation is succeeded then call will happen properly as per treatment.
10-26-2022 06:16 AM
In my case, the problem was that the script had duplicated labels, which made it invalid.
Remember to validate the script beofre load it. Don't be like me
