03-23-2020 04:28 PM
I have UCCX 11.6(2) running with CUCM 11.5.
I have been trying to get Jabber with Extend and Connect to work for UCCX agents.
E&C seems to work fine outside of UCCX but there are problems with UCCX.
When I log into Finesse the agent gets an inbound call as expected. However this call drops after a few seconds. I have tried various remote destinations including a standard PSTN landline and iPhone and Android mobiles but see the same behaviour on all.
The expected behaviour is for the call to stay up as described in the link below.
Does anyone have this working? - any idea why the call should be dropped?
03-24-2020 07:41 AM
03-24-2020 07:50 AM
Hi Anthony,
Thanks for the response. This is not top of my priority list at the moment to be honest - I am busy scripting and configuring MRA stuff to allow staff from one of our big public sector customers to work from home.
I was looking at mobile agent solutions from Comstice and Novelvox which would allow agents to work pretty much anywhere but both rely on Extend and Connect for the voice part so I quickly set it up and tested last night.
I am not sure whether it will be a viable solution for this customer as each Finesse agent permanently ties up a SIP trunk channel even when not on a call.
I would appreciate your feedback if you do set it up.
Cheers
James
03-24-2020 08:37 AM - edited 03-24-2020 08:39 AM
Ok, that was a lot easier than I was thinking.
CUCM 11.5(1)SU5 and UCCX 11.6(2)ESsomething. Already have a working Jabber deployment, just needed to try out EC.
I used the steps in this document to just get EC working at all. Like if I call the DN, does the remote device ring, and the answer is yes. And it stays up for longer than 30 seconds (typical length for testing):
Then for UCCX, I just assigned the CTIRD to the RmCm user, assign the DN to the users IPCC Extension, and the rest is basic stuff. Skilled the Agent, signed them into Finesse and the RD rang, I answered, it stayed up for more than 30 seconds. I then moved to the Ready state and took a queue call, and that came through as well. Kept it up for over 30 seconds too.
I did see in this guide, that you can configure two custom announcements, which I think is cool, but I didn't do that part:
PS the UCCX document is pretty trash for setting up EC from scratch. I feel bad for anyone using it to get going, especially if you don't know what you're doing. I would recommend using other guides to get your Jabber deployment working first, then use the CUCM guide to configure EC per user, then use the normal UCCX Agent setup guide to configure the Agent like normal, just refer to the CTIRD as the Agent phone.
03-24-2020 09:20 AM
Thanks Anthony,
It is useful to know it works ok for you using similar versions to what I have.
I will have a look at some CUCM logs when I get a moment.
03-24-2020 09:22 AM
05-20-2020 05:54 PM
Realised there was lack of clarity in Documentation. Could you have a check on the below document for basic setup for Extend and Connect with UCCX.
05-21-2020 01:40 AM
Thanks for putting this useful document together.
In the end the customer I was looking at this for went with using MRA to register remote agent endpoints so E&C was not required.
I will work through your document when I get a moment though as I would like to see if I can get it working for my own satisfaction.
06-22-2020 01:02 PM
The jabber here is just so they can show E&C from the remote side, it doesn't have to be a jabber client, could be anything (home phone, cell etc).
basic logic is remote cti configured as ccx phone and doing SNR to the actual agent phone.
08-05-2020 01:41 PM
08-05-2020 07:10 PM
Thats my understanding, although it does make sense to use it so the agent has control on what PSTN number to ring.
