Unable to connect Finesse- db_phx_config DB using SQL work bench
smeegada1
I am trying to connect Finesse db_phx_config DB directly using SQL work bench.Does anyone successfully connected and please share URL string to connect? We have to pass value in INFORMIXSERVER which i have tried with server name/Finesse but no luck.
jdbc:informix-sqli://XXXXXXX:1526/db_phx_config:INFORMIXSERVER=
Any help is appreciated.
dekwan
As far as I remember, the db_phx_config DB isn't meant to be connected to. You can obtain all of the data from the DB using the Finesse APIs.
Thanx,
Denise
